Hi - I am going to Peru later this year and would like to find out about roaming charges if I want to make a call, send a Whatsapp message or a text. Is it likely to be very expensive?
https://www.idmobile.co.uk/help-and-advice/international-and-roaming-charges - select Peru from the list to view charges
Roaming | Pay monthly | Pay-as-you-go |
Calls to UK* | £6.00 | £6.00 |
Calls to Peru* | £6.00 | £6.00 |
Calls received* | £2.40 | £2.40 |
Texts to Peru** | £1.20 | £1.20 |
Texts to UK** | £1.20 | £1.20 |
Picture message (MMS) sent** | £0.60 | £0.60 |
Internet and Data (per MB)*** | £15.00 | £15.00 |
* Price per minute
** Please note: MMS charges vary. For further information, refer to Terms & Conditions.
Looks like roaming in PERU using iD Mobile is expensive… might be worth looking at using an eSIM instead, if your handset supports these
Hey
Just be sure to cap your plan at £0.00 and configure the eSIM correctly.
Hi Mohammed - many thanks for taking the trouble to reply. I'd been thinking about a local SIM. Thanks to everyone for your help and suggestions.
Glad that we could help.
Thanks Kash
