is it easier moving to iD to 3 as iD use 3 network?
It should be easy to move to any network these days. You'll find iD is much cheaper than Three though.
If you decide to move to iD, remember to ask your existing provider for a PAC (Porting Authorisation Code) if you want to keep your current mobile number. You can then enter this code in your iD Mobile account to transfer the number.
Why iD
Mobile?
