Hopefully I will be going overseas at the end of May. Normally I would cancel my existing SIM only plan. However for convenience I thought that I might reduce my monthly SIM only plan to the minimum available & keep it until I return 5 months later then upgrade again. Is that possible & if so what is the lowest no contract SIM only plan?
How much notice of a change would I need to give to change plans & would that incur changing my existing SIM?
Thank you...
Best answer by Kevin
