How do I change the best answer for my topic question?
View originalHow do I change the best answer for my topic question?
View originalYou can’t - once you’ve selected the “Most Helpful Answer”, it’s game over.
Good luck
Good luck
that’s clever
Hello
An Admin or Moderator is able to untick an answer as Most Helpful and you can re-select one if you wanted.
Was this for one of your topics?
Hello
It was yes, my “Is Unlimitted really unlimitted?” thread
