OK I'm London most of the time and I still have dropped calls regularly. I first reported on here about that issue about Services to this number are not allowed etc and all calls were regular mobile numbers. Since then the members on here and administration team have posted about such problems and no updates from 17/ 18 January 2024.
So once again I have excellent coverage and I have at least 10 device I've tested my sim card in and same problem all over as I travel all over the UK.
I just want to find out how so many people on ID are experiencing the same problem and and there's no regular updates.
Also the issue with the voicemail embedded number in the sim card where you can't edit the number to the correct voicemail number of +447782333123 so you can use the voicemail shortcut on your keypad (1). Instead the number is +447782333129 which doesn't allow you to connect to voicemail using the voicemail shortcut, remarks like you can dial 123 or +447782333123 from your phone from admin staff on here is not what we as paying customers need to hear or read. The fault lays with IDMobile like so many faults some over 4 years from what I've seen on here and we read that they have be solved where they clearly have not.
And before I get flooded with questions like have I done x, y, Z yes without going into things I work in this industry engineering side of things.
Back to my problem of dropped calls, call cutting off while you've been talking has IDM got a network wide problem and is the a stated update on said problem with a progress report.
Thanks for reading my post.
Best answer by WelshPaul
