Hello,
I am kinda confused as to how the roaming system works, for example if i were to travel to japan would I have to pay per MB used or would I be using my data from my current allowance?
View originalHello,
View originalOkay
If you roam elsewhere, for example in Japan, you’ll be charged at the roaming rates applicable for the country in which you’re roaming.
The roaming charges for Japan are:
Ohhh so would it be financially better to get a local sim there? For the duration of the trip?
Most likely
If I turn off data roaming in app and on my phone whilst in Japan, and only use hotel wifi for calls, data etc, will I still get an out of area charge from ID.
Just set the bill cap for your iD account to £0
Thank you. Had a bad experience with previous provider. Did all they said and still got charged. Don’t want to make the same mistake.
