I am in the USA. Data roaming is on, I’m no where near my cap. It appears that while I can make calls to USA numbers +1…, I can NOT make calls to UK numbers +44…
I’ve tried using both AT&T (which ends my calls instantly), and T-mobile, which tries but fails to make a connection and then tells me it is unable to connect. I’ve tried forcing network connections to 3G or 4G. I’ve tried with wi-fi calling on and off. None of these permutations succeeds.
I hope someone can help. I really need this because I am with my wife, who has an identical Pixel 6a and ID mobile account and we’d like to be able to communicate when we are doing different things. But just to be clear I’ve also tried ringing a UK landline number and that also won’t go through.
Steve
