Since porting to ID from Vodafone. I have noticed that my normal calls drop both on sim calls or WhatsApp calls …also my sms messages do not get delivered always…please advise
It might be a SIM card problem - does your iD SIM card work properly in a different phone
I’d recommend double checking your postcode on the iD Mobile Coverage Checker and the Three Outage Checker to see if your local area is recommended for our signal/may be having an outage.
Have you tried the SIM in another device? Does the same happen in the other device?
When dropping WhatsApp calls is this while on Wi-Fi or mobile data?
Why iD
Mobile?
