Data disapear
  • 3 September 2023
  • 20 views
My data has just renewed on 23rd of august (50gb) and after 10 days received a message from Id i’ve used over 80% my data, i don't know how as i mainly use my data to work.
Best answer by WelshPaul 3 September 2023, 14:13
What phone do you have? There will be logs stored on the device that will tell you exactly what used what.
Hi @Odair,
As @WelshPaul mentioned you can usually check the data usage on the handset.
On most handsets you can access the data usage via your settings which will show how much data you used between a certain period and what you used it on.
