I am heading to the Philippines at the end of this month and wondered what my data roaming charges would be?
thanks in advance
View originalHi,
thanks in advance
View originalYour data roaming charges would be £9.60/MB (i.e. next to “Internet and Data (per MB)***”), as shown online on 07-Nov-2022.
Good luck
We are going to the Philippines and I wondered if I can use my phone freely or if there is an add on that I need to buy?
Can’t buy an add-on.
Can’t use your plan’s allowances in Philippines.
If you have a high enough setting for your account bill cap, you can pay-as-you-go while roaming in the Philippines.
