Data Roaming in USA
  • 17 September 2022
  • 387 views
Hi, I have a Huawei Mate 20 Pro Model LYA-L09 and trying to get it to work in N America. Are you aware of any incompatibilities with the carrier networks? I can pick up T Mobile and AT&T.
I have my roaming enabled both on the phone and in the app and sufficient data on my plan.
If you look at the AT&T web site, they don’t list your Huawei handset as tested and supported for use on their network.
The T-Mobile online page https://www.t-mobile.com/resources/bring-your-own-phone, might help you determine if your Huawei will work on their US network.
Anyway, good luck @Mark Cantwell.
Hi @Mark Cantwell
With the bans that North America have in place on the Huawei models this could present some issues, I’d recommend the above @andewhite suggests and check on the individual carriers to see if they support Huawei devices.
