Data speed
  • 17 April 2022
  • 1004 views
Hi everyone,
Does anyone knows, what is data/internet speed, for example, for £10 60GB 12 months contract? Is there different speeds for different contract or all same?
Robertas
Best answer by Robertas V 19 April 2022, 05:53
There are no speed caps in force with ID Mobile. The speeds you get will depend on various factors such as signal strength, local mast congestion and if your connected to a 3G, 4G or 5G mast.
I'm with Smarty (uses Three network, same as ID Mobile) and I get almost 500MB down with 5G.
What is Smarty?
A Mobile network here in the UK.
I get the same speeds on ID Mobile too! They both use the same network to provide their services.
If you get poor speeds and coverage on ID Mobile then you will get the same poor speeds and coverage with Smarty and Three too. They are the same network!
