Default SIM PIN
  • 24 February 2024
  • 307 views
For reference, the default iD Mobile SIM PIN is 0000.
(ZERO,ZERO,ZERO,ZERO)
WARNING - You get three attempts at entering the correct SIM PIN before the SIM is blocked. A *PUK code is required to unblock a blocked SIM.
*The PUK (Personal Unblocking Key) code is a code consisting of 8 digits. It is used to unblock your SIM card when you entered 3 times a wrong PIN code. A card blocked by the PUK code cannot be unblocked; it cannot be used any further and you have to replace it.
Also, if you change your PIN code, make sure you remmeber the new one. Otherwise you will be locked out.
Hi @WelshPaul,
Thanks for posting this.
Hopefully it can help a lot of users that experience this issue.
