Why does my DD keep failing, I pay off the debt, set up the direct debit again and it fails again. Same bank that Ive been using the last 18 months, it was OK before
iD Mobile have probably changed their customer account systems, behind the scenes, and made things less reliable than before.
Good luck
You will also be able to check your payment method via the iD mobile app.
-Lauren
Why iD
Mobile?
