I’m on a SIM only deal with ID and I’m looking to upgrade for more data. If I add a plan to the basket and proceed through the checkout, is that all I need to do? Do I need a new SIM delivered or anything delivered? Or is it all done over the ether as it were?
That depends on whether or not you’ve following the official iD Mobile process to change or upgrade your existing plan
It’s very easy to order a new plan, instead of changing/upgrading your existing plan.
If you order a new plan, you’ll get a new SIM and new mobile number.
I’d recommend reading the following:
Although some articles talk about upgrading handsets, the same applies for SIM only upgrades.
Why iD
Mobile?
