Anyone else having issues this morning seems like it happening every week now
Yes, me too. Waiting for my otp to come through to make card payments. Absolutely nothing happening! I'm trying from Kent.
We are sorry to hear the issues with your coverage.
If you and
Are you able to provide a postcode for us to check for you?
Hi Kash,
I work in central London. I have a colleague on the 3 network. We stand outside together and he gets 5G and I only get H+
Please advise.
Marcel
Hi Kash,
Please advise.
Marcel
Do you both have the same handset
Are you on the same device?
Have you tried resetting network settings?
Hi Tom,
We're on different devices and I have tried to reset network settings. H+ seems to be the maximum
Hi Kash,
Please advise.
Marcel
Different handsets
Hi Kash,
Please advise.
Marcel
Different handsets
Does your iD SIM card get 5G when you use it in your work colleague’s handset
Is your handset approved by iD for use on their network
Check the online list at https://www.idmobile.co.uk/help-and-advice/approved-handsets.
