HELP cant send texts
  • 8 April 2022
  • 475 views
None of my messages are sending, saying they have failed. I have done a network reset and it still isn’t working
Userlevel 5
Hey @Shelby Ford, if you’re using an Android device, could you please try the following for me?
  • On your device, open Messages
  • At the top right, tap Settings
  • Tap Chat features
  • Toggle 'Enable chat features' to OFF
  • Try to send a message again
If you’re using an iPhone, please try the following:
  • Turn off iMessage (Settings > Messages)
  • Restart your phone (by pressing and holding the on/off button)
  • Tap Settings > Phone > My Number and confirm that it is correct
  • If it is not correct, please enter the correct number
  • Turn iMessage back to On (Settings > Messages)
  • Finally, go to Settings > Messages > Send & Receive and see if the correct number is displayed under "Start new conversations from:"
Let us know how you get on!
If these steps don’t work, it could be a network issue in your area that’s causing problems. To check, please enter your postcode here.
Rory
