help logging in
  • 22 April 2022
  • 48 views
I have an account, receive emails, so I know I'm registered.  When I try to reset password it gives me an error message saying details not recognised.  I've slso tried to set up an account and it says email address already in use so I know I have one.  Can you help please as I need to make adjustments and view bills.  Thanks
iD Mobile have a weird username system where the username cannot be changed and the email address registered against an account isn’t necessarily the same as the username.
Have you tried this:
https://my.idmobile.co.uk/web/cpw/forgot-username/
Yes thanks I had tried that but it just says details aren't recognised.
Userlevel 5
Hi @Sarah21993, did you manage to get this sorted? If not, I’d recommend speaking to the Live ChatFacebook or Twitter teams.
Rory
No unfortunately at the moment I have no access at all to the account.  Yes I will have to do that , as it looks like there us no other way to contact ID. Thanks
