Been charged for 2 calls two different mobile numbers they are not out of plan but still been charged why ??
Best answer by Mohammed
View originalBeen charged for 2 calls two different mobile numbers they are not out of plan but still been charged why ??
View originalI have been charged to phone to mobile numbers yet I haven't used my minutes only phoned company's that are local to me
Okay
If you’ve called a non-UK mobile number you’d be charged for the call.
Okay
If you download the PDF copy of the monthly bill for the time period the charges occurred, you should be able to identify the two numbers called.
Unfortunately
Non-standard 07 numbers are charged at 40p/min.
There doesn’t appear to be any information on the iD website about their non-standard 07 numbers - the iD customer service team should be able to assist though.
Sorry, iD non-standard 07 numbers are online at https://www.idmobile.co.uk/nonstandard07numbers.
Hey
What’s the prefix for numbers you have called?
Have you viewed the bill to see what the breakdown of the charges are for? Assumin that the bill has been produced.
I did they just look like normal 07 numbers only 40p per call just seems strange
Hey
This sounds like a call to a non-standard 07 number.
Edit: I’ve merged your posts together into one topic.
Hey
Indeed yes
