How can i prevent roaming in Turkey
  • 27 September 2023
  • 358 views
I am going to Turkey next month and I want to prevent my phone from roaming. I don’t want to be charged for incoming calls or texts. How do I prevent this?
if I disable roaming in my account in the ID mobile app will it prevent my phone latching onto a local Turkish airtime carrier when I’m there?
I want to use only hotel WiFi and data-only calls eg WhatsApp audio or Messenger audio
thanks in advance for any advice or instruction
Best answer by andewhite 28 September 2023, 01:43
Just set the bill cap for your iD account to £0 @Michael Hicks
Doing this will prevent any out-of-plan charges while roaming in Turkey.
Text messages are free to receive when you’re roaming.
Hi @Michael Hicks
I’d recommend the same as @andewhite above, set the bill cap to £0, we won’t charge you anything extra.
