How can I view my current roaming usage?
I had to use it recently in a country outside of the free roaming destinations and now I want to know what the cost of that, but I can't see an itemised cost or the cost of add ons on the new app
The itemised costs - if incurred - should be shown in the monthly bill covering the time period spent outside the free roaming destinations,
You can also use a web browser to look at your iD account, from https://my.idmobile.co.uk.
Thank you for your answer. I used roaming data about 4 days ago and it isn't there yet. Would it be there before my bill is calculated in another ten-days or so? I used roaming to message my family, but I forgot to turn off the updates over cellular data 😑
Unfortunately
