I referred my brother to ID mobile back in July. He definitely used the link so I should be getting the referral money. I haven’t heard anything since, how long should this take to come through?
What did the terms and conditions say? Usually there is a 90 day minimum waiting period.
As
You can check the terms and conditions at the link below to confirm that you have followed the correct steps.
https://www.idmobile.co.uk/legal/terms-and-conditions-refer-a-friend
