How to conceal my private number when I call someone back -141 does not work?
  • 27 February 2024
  • 854 views
I need the facility to call someone back for business purposes without revealing my personal number . 141 used to work but not any more?
Best answer by WelshPaul 27 February 2024, 21:38
141 isn’t available on the THREE network or any MVNO that uses the THREE network to supply their service. You need to configure your device to hide your number. Here’s how:
iPhone:
  • Phone > Show My Caller ID >  Disabled
Android:
  • Phone app > 3 dots top right corner > Settings > Calls > Additional settings > Caller ID > Hide number
How you hide your number varies on Android, depending on the manufacturer. The example given above is how to hide your number on a Google Pixel phone running Android 14.
Thank you for that but when I try to do that it says contact your carrier -I take it that means your provider and mine is Id sim card only?
What phone and OS version are you using?
I am able to select Hide number:
Made a test call and the number was withheld.
its a mototola e13
Are you pay go or pay monthly? Android version?
I believe on a Motorola the setting is located here:
Phone app > 3 dots top right corner > Setting > Calling accounts > iD Mobile > Additional settings > Caller ID > Hide number
Maybe try restarting the phone?
Thanks a lot - I got it now
Hi @Caroline Norling,
Glad to hear that it has been resolved.
Please get back in touch if you require further assistance.
