ID sim card doesn't show up on Pixel 8 Pro
  • 31 January 2024
  • 106 views
As topic states when inserting ID sim into pixel 8 Pro nothing happens it just doesn't show up even as inactive.  Tried different Sims from three , EE , O2 , Vodafone all them work fine in this phone.  Then inserted ID sim card in wife's phone, working fine , back in mine and it's not showing up again.
Best answer by Lauren 1 February 2024, 14:59
Userlevel 4
Strange one have you gone into the settings for the sim and used the manual search for network and select ID Mobile once it comes up?.
Settings > Connections > Mobile networks >Network operators deselect Automatically this should start a search manually for the network's and all possible networks should be listed. There after if listed select ID mobile.
Hi.
I understand what you wanted me to do BUT - as I mentioned the SIM it self doesn't not even pop up (even without network) its like sim try would be empty. But as I said I've tried different options to determine possible error but without luck.
Sounds like there’s something strange going on between your new Pixel 8 Pro and the iD SIM card, which appears to work in other handsets, as do other SIM cards in your Pixel handset.
Have you tried a replacement iD SIM in your new Pixel handset, @Ed_?
Userlevel 4
Badge
Hi @Ed_, we’ll look at sending out a replacement SIM.
-Lauren
