is this actually in stock?
the expected date shown on the website was end of august.
What colour are you after
The Alpine Green iPhone 13 Pro Max is in stock now - it’s not a bad colour.
Hello
Let us know which size and colour and we can check for you.
Stock varies based on this and at the moment, this device along with the 14 is very popular so we’re most likely just awaiting stock from Apple for these.
Hey, I recently just bought the Sierra Blue iPhone 13 Pro Max through ID Mobile under the guise that it was in stock as I was able to make the purchase - I don’t want to cancel the order but I was hoping to find out if there is a time frame given for when it is due to be back in stock as that is not included in the email.
Thanks!
Thanks!
Try calling the iD telephone sales team on 020 7139 1397, during normal office hours.
Have your order number ready.
Good luck
Unfortunately I believe all iPhone 13 Pro and Pro Max models are now in ‘end of life’ status which means we won’t be getting any more stock of these models.
However to double check I’d recommend the above from
Having a similar issue just wondering how long it took to arrive or if it even has arrived as I ordered the pro max sometime last week with an email saying that they were out of stock, also if i should contact them just to be sure or wait a couple more days, just worried it won’t come now haha, thanks!
