I have recently swapped to ID and my messages won’t send correctly, I see this issue has been spoken about for over 2 years now and I see there is a work around. However this settle for a workaround is not good enough.
I say it’s not good enough as the workaround doesn’t even work in my case. I have turned off iMessage (which I shouldn’t have to) to send messages.
This is the exact issue I’m having:
I send a message, the message goes through, however I get a Green bar as to say it still sending, in this time I cannot send any more messages and then get a “cannot be delivered” notification after every message I send. Along with this messages can take up to 10-15 minutes to send!
Any help would be appreciated as I’m considering dropping ID after only experiencing the services for a day, which I ideally don’t want to have to do
