network - wi-fi
  • 1 November 2023
  • 25 views
hello all hope you can help
i just moved in to a flat and i’m got getting good network so i pout it on to wi-fi calling and that keeps dropping signal, can you till me step by step what to do so the i can get good network signal and good wi-fi signal
i have a Samsung s20
thank you
Assuming you’ve got a reasonable Wi-Fi network in your flat @lucy2020, try putting the phone into flight mode, turn on the phone Wi-Fi, and then enable Wi-Fi Calling.
Hi @lucy2020
I’d recommend trying the above from @andewhite, the strength of the Wi-Fi calling would rely on the strength of the Wi-Fi connection.
