My phone can't connect to a network in Jersey Channel Islands. I have roaming enabled and have been using my phone there fine until yesterday. Are there any technical issues?
Best answer by Kash
View originalMy phone can't connect to a network in Jersey Channel Islands. I have roaming enabled and have been using my phone there fine until yesterday. Are there any technical issues?
Best answer by Kash
View originalHi
Have you tried removing the SIM for a few minutes whilst the handset is off?
It may also be worth doing a network reset on the device.
Thanks Kash. It turns out that manually selecting the network makes it connect. For some reason it does not automatically connect to a Jersey network. It's not my phone as I have tried it in another phone
