Hello there
Since this morning I don't have signal, couldn't make calls or even send text messages.
What's happening please.
Thank you.
Hello there
Thank you.
Does your phone or iD SIM card have a fault, otherwise do you have an outstanding bill,
If your bills are up to date it sounds like it may be an issue with the SIM or handset.
It may be worth testing the SIM in a different handset to see if that improves things.
You can also check your coverage and network status by entering your postcode at the link below:
