O2 nber not ported properly
  • 29 November 2022
  • 6 replies
  • 83 views
Evening everyone.
I moved to ID from O2 and received my new 'phone a week ago. My calls are ported to my old O2 new as is WhatsApp, etc.
Texts are being delivered with my new ID number.
Can someone help please?
Cheers
Best answer by andewhite 30 November 2022, 09:43
What’s the make & model of your new phone being used with your iD SIM @Roxy'sGandah?
Hi andewhite.  Google Pixel 7
Okay @Roxy'sGandah, if want texts to be delivered with your old O2 number, then just TURN OFF the “Chat features” option in the Messages app on your Pixel 7.
If you leave the “Chat features” option disabled, your texts will come from the O2 number, which you switched to iD.
Good luck @Roxy'sGandah.
Cheers
I'll give it a whirl.
Hey @Roxy'sGandah,
Did that fix the issue for you or are you still having problems?
Cheers
Morning everyone
It worked, thanks @andewhite for your help and apologies for not letting you know the outcome.
