Hi, I have turned the filter off but still unable to visitĀ over 18 sites. obv Wifi is fine and all lockes are disabled in search engines
Hey
Assuming you turned the feature off and are using Mobile data, try powering down the phone for 10-minutes.
Then power the phone back up and this should update your network settings. Then test again on mobile data.
Why iD
Mobile?
