Hello. I received a new SIM card, inserted it into the phone, but the phone does not recognize the card, writes Insert a SIM card! Tested on Samsung Galaxy S23 Ultra and Oppo Find X3 Neo
If the SIM doesn’t work in either the Samsung or Oppo handsets, sounds like it’s broken/damaged, or the SIM card might be inactive.
You might need to request a replacement SIM cardÂ
Â
Let us know if you require any assistance with activation and we can help you out via PM.
Â
HiÂ
Â
I just activated the replaced SIM card, everything is fine. Only very weak 4G and 5G signal, HU9 4SU area....
My wife has been with 3UK for 2 years already, this status Works in progress, all these 2 years for our location. ))))Â Â Hope something changes...
Me too - at least for the last 6 months.Â
Anyway, Three UK (iD Mobile’s network partner) are decommissioning their 3G network right now - with works scheduled to be completed end of 2024.
Maybe this message will disappear post-2024?
HiÂ
Â
Some works are a little more complex due to access to sites etc.
Hopefully the work is completed soon!
Â
