I have changed my number over a few weeks ago with the pac code but when messages sometimes the temporary number that was given with phone comes up to the people I'm texting. How do I resolve this?
Sometimes doing a NETWORK RESET on your handset resolves this issue
The handset user guide will normally explain how to do this.Â
Â
Are you on an iPhone or Android?
Â
For iPhone I’d recommend trying;
Â
3) Tap Settings > Phone > My Number and confirm that it is correct.Â
Â
Â
For Android I’d recommend trying;
Â
Alternatively, you can turn Chat Features/RCS off and test SMS after this.
Â
