Just got this phone, really impressed with it so far... One issue though, the screen is "apparently" soft and prone to scratches. I have purchased a tempered glass protector which has a visible circle to allow for fingerprint recognition. The glass fits perfectly giving full screen coverage but the fingerprint sensor is now useless. Can anyone recommend a reliable screen protector that actually works? Cheers 👍
Protectors are it and miss I find buying from amazon, best bet is goto a phone shop and ask them to fit a protector that still let's you use the scanner and say you won't pay unless it works.
Is it not picking up the finger print at all?
Looking online I can see that some people have advised to re-register the finger print.
It may also be worth looking at alternative screen protections online that work with finger print ID, as I can see that there are some specific ones for this.
I’ve not come across this issue before so I apologise that I can’t provide much insight into it.
