I keep having issues with having 1 bar or no signal in my local area the coverage map says its fine but i am not receiving calls or messages
Try checking online for any local signal issues of faults, using the network status checker page at https://www.three.co.uk/support/network_and_coverage/network_support.
Have you checked the network status in your area to see if there are any ongoing issues?
If you require further assistance, please let us know here.
Thank you, this still says the same had to change to 4g but it's still giving one bar signal even though it says good coverage inside and outside
Both 3 and I'd says good coverage indoor and outdoor but 1 bar of signal on 5 and 4 g so unsure on the issue
Hello
What’s the full postcode of the area you are facing issues?
Have you tried turning on WiFi Calling in-case the issue is down to blackspots indoors?
Have you always had this issue or has it recently dropped?
Hello
Hi, the full postcode is SK16 5JJ.
WiFi calling is on its a recent thing within the last two weeks I'd say.
James
Okay
Wi-Fi Calling can be useful for fixing poor indoor coverage - anyway, good luck
Thanks for letting us know
Using that postcode on the iD Mobile Coverage and Outage checker it doesn’t look like you should be having any issues currently.
Are you able to try the iD Mobile SIM in a different device?
