primary and mobile data
  • 22 September 2022
  • 246 views
I have just moved from EE to iD - I got a new phone as well. I have transferred all apps etc and all fine. I got a PAC code and this has been accepted however now I seem to have 2 networks connecting.
I have mobile connection to iD and primary is connected to EE. I turned to phone off and on again and now primary has changed to business.
I have 2 signal bars in the top right of my iPhone as well.
When I try to make a call it says “last line no longer available - do you want to call with one of your remaining lines?”
I have no idea what any of this means. Can you help?
Best answer by Danielle Ware 22 September 2022, 21:22
I’ve sorted it! For some reason it set me up as having a dual eSIM which was keeping me connected to EE. I’ve just worked out how to remove it myself and made iD the primary now :)
Badge +3
Hey @Danielle Ware
Welcome to iD and the Community!
Glad to hear you’re up and running 😊.
If you ever need any further support, the Community is here to help.
Nikhil
Hey @Danielle Ware,
Glad to hear you got it sorted and thanks for sharing.
I came across a customer with the same issue last night also which was very odd.
