I put my new sim in on Friday and waited for it to start working but it hasn’t I don’t know what to do
View originalI put my new sim in on Friday and waited for it to start working but it hasn’t I don’t know what to do
View originalIs the new SIM a replacement you’ve ordered, or have you purchased a new SIM plan with iD?
It is one I ordered from online
Okay, new SIM cards are supplied by iD already activated.
Given what you’ve posted it could be one of several things:
Replacement iD SIM cards are not activated.
They always need to be activated before they can be used.
Anyway, good luck.
Anyway, good luck.
hi how can I check the id mobile signal
Try these links, with your postcode:
Good luck!
Good luck!
I have checked them and there isn’t a problem what should I do if it’s my phone
