I've landed in Spain today but despite getting the text confirming roaming I can't use data/calls/texts. Do I need to change some settings on my phone?
Best answer by Tom
View originalI've landed in Spain today but despite getting the text confirming roaming I can't use data/calls/texts. Do I need to change some settings on my phone?
Best answer by Tom
View originalHi
Â
You may need to change settings on your device and in the iD Mobile app/website while logged into your account to enable roaming while in Spain, then you should be able to use your iD Mobile plan like home.
Â
https://www.idmobile.co.uk/help-and-advice/roaming-advice
Â
