Hi, I changed to a new plan last month, from 1gb to 4gb. When the month ended, I had 4.2gb overall left (started with 5.29gb) but at the start of the next month it reverted to 4gb total allowance. Should the 4.2gb, or at least, a portion of it not rolled over? Thanks for any help
You can't roll over unused data from the billing period when you changed plans. Instead, your Data Rollover will re-start at the beginning of your new plan.
So you're telling me that I had 100gb of data so I changed my plan to pay for less data for a while and you steal all my rollover data!
Didn't explain this scam very clearly did you.
I’d recommend checking our plan change page with the following statement;
https://www.idmobile.co.uk/help-and-advice/plan-changes
Why iD
Mobile?
