Samsung J6
  • 19 April 2024
  • 23 views
Samsung J6 just unlocked from EE will not read the ID Mobile sim. It does read GiffGaff and other makes. Is there an issue with Samsung and ID sims?
The J6 is approved for the iD Mobile network, @Bob Pike.
Check at https://www.idmobile.co.uk/help-and-advice/approved-handsets.
Does the iD SIM card work in another handset? It could be damaged / faulty, or not active.
It is working in a Blackview A70 and a Google Pixel 7. When put in the J6, in the 'about phone's is checked, no number or service  appears. It is however working with a new Giffgaff SIM.
@Bob Pike,
Have you got access to another iD Mobile SIM?
We can send out a replacement SIM to test or you can get one from your local Curry’s store.
