Though network status for my postcode shows no issues, I’m regularly seeing the signal strength on my Huawei router dropping from 5 bars to 1, with subsequent speed deterioration; could this be a Router issue, or the local mast [which I can see across the fields]?
Please could you let us know the postcode(s) where you’re having this issue?
It’s worth noting that we don’t officially support any routers at this time, usage of an iD Mobile SIM within one may not work correctly.
Regularly dropping to 2 bars especially in evenings; local mast is at Stanmore Reservoir, north of Newbury.
Mast postcode RG20 8SR.
same drop early evening down to 2 bars from 5; surely 3’s monitoring logs must highlight this?
It sounds like there may be congestion at the mast at specific times.
Is it something you are experiencing everyday?
