What is the default SIM pin for a new SIM being used in a new phone.
as I want to lock the SIM
Please let us know how you get on with the codes that
Tried ano number, but that leaves 1 attempt left; so I would appreciate the true pin please anyone
thanks
If it isn’t either of the pins provided don’t work it may be 1111 or one you have set yourself.
Our default PIN is 0000 or 1234, however some may be 1111.
If these don’t work it’s likely that the PIN is one that you set yourself.
Once the SIM is blocked we’ll need to provide a PUK code.
