SIM Default Pin
  • 13 November 2023
  • 83 views
What is the default SIM pin for a new SIM being used in a new phone.
as I want to lock the SIM
Have you tried 0000 or 1234 @Paul Goodwin?
Hi @Paul Goodwin,
Please let us know how you get on with the codes that @andewhite provided.
Tried ano number, but that leaves 1 attempt left; so I would appreciate the true pin please anyone
thanks
@Paul Goodwin,
If it isn’t either of the pins provided don’t work it may be 1111 or one you have set yourself.
Our default PIN is 0000 or 1234, however some may be 1111.
If these don’t work it’s likely that the PIN is one that you set yourself.
Once the SIM is blocked we’ll need to provide a PUK code.
