"Something went wrong" error
  • 13 August 2023
  • 9 replies
  • 503 views
Hi, I've been trying to change my plan both on the app and website, but I keep getting this error message. I open the app, go to my account > change plan > then I select the recommended plan, and tick to confirm I've read the necessary information, but after I do that and confirm I want to change my plan, I just get the error message. The same happened when I tried on the website just now, after reading the advice on a 2 year old thread where someone else had a similar issue
Would it be possible to please change my plan from your end?
Thank you
The error is thrown when you try to change to a cheaper tariff when locked in to a minimum term contract. You can only move to a more expensive tariff if still within your minimum term.
Hi, not the case here. My current tariff is £22.66. I'm trying to change to one that's £22.99, and it's also the only suggested one to change to
Hey @hiding, if you meet all eligibility criteria below, and you still can’t change your plan in the app or online, you’ll probably need to speak to iD via live chat, Facebook Messenger, or X (Twitter) DM.
Hi, thanks for getting in touch! I do meet all the criteria, I'll try live chat now
Hey @hiding,
Have you managed to get this sorted after contacting or still need help?
Can send you a PM if needed to pick this up if you haven’t been able to get support yet.
Hey @hiding,
Hi Mohammed, I can't access the app right now, it says too many people are using it for me to sign in. If you could please PM me to resolve this I'd appreciate it, thank you :)
Hi @hiding
Hi, just driven 50 miles to install an iD mobile sim card for my mum.
Having entered the details and PAC code only to be greated by a "Something went wrong" message.
Seems iD have a history of this and it's still not been fixed. Disappointing.
Wasted journey in the dark, elderly Mum stressed and feeling guilty.
Wishing i hadn't convinced her to move from Vodafone.
Still getting the message.
How do i fix this problem in your software?
Hi @SimonC
I’m sorry to hear this, does the transaction number you’re using begin with a 4?
