Swapping Phone Numbers
  • 24 October 2023
  • 95 views
I have just bought an Iphone from Id Mobile and got a new number with it. I currently have an old contract still active with ID Mobile and would like to swap my new number with my old number. Is this possible?
Best answer by andewhite 24 October 2023, 17:12
Currently you can’t transfer a number from one iD contract to another iD contract @JasperSmit.
To use the number you want to keep with your new iD contract, you’d need to perform a triangle port.
  1. Get a PAC for the old iD contract.
  2. Give the PAC to another service provider.
  3. Wait several days - get a PAC from the other provider, for number to want to keep.
  4. Use the PAC from step 3) with the latest iD contract - the one you plan to keep.
It’s a faff doing all this, but you should be able to use your old number with the new contract.
Hi @JasperSmit
Unfortunately it isn’t possible to move a number from one iD Mobile plan to another one directly.
Numbers can only be transferred from another network via PAC code.
