tenerife
  • 16 April 2024
  • 49 views
I am in tenerife shows 4g but I can’t make any phonecalls or use internet and everything is on
Sounds like ROAMING is not enabled for your iD account, or on your handset, or both, @Ruxymaria
Have you checked in the iD app or online at https://my.idmobile.co.uk?
Yeah I checked and is on
Okay @Ruxymaria, so your iD account has ROAMING on, and your handset is set to allow roaming?
The iD Spanish roaming partners are Movistar & Yoigo - maybe try manually selecting a mobile network to use.
​Hi @Ruxymaria
Have you checked the above from @andewhite and tried connecting to Movistar and Yoigo?
You’ve mentioned calls and data not working, how are texts with SMS?
