I'm due to upgrade in 2 weeks time from a sim contract,does anyone know if they do a credit check when upgrading to a handset?
Best answer by Gregor
View originalI'm due to upgrade in 2 weeks time from a sim contract,does anyone know if they do a credit check when upgrading to a handset?
View originalHey
Â
As long as you had your SIM only contract with iD Mobile for a least 6 month then there will be no credit check required. They will check history of your past payments and you will be good to go 🙂
Â
Kind Regards
Gregor
Â
