Hi there,
I have a plan that I pay £8 a month for. I’ve checked and the fair usage policy abroad in the EU is 6GB. I am likely to exceed this. Is there a way to upgrade this temporarily for the trip?
Thanks!!
Hi there,
Thanks!!
An add on this - if I were to purchase a data add on, would I be able to use this on top of the 6GB allotted fair usage and would the data add on also be subject to any fair usage caps?
Thank you!
Fair usage would apply if you roam more than in the UK over a 4 month period.
If you are visiting an EU inclusive country you can use the full data allowance.
Hi Kash,
thanks, so as an example this is a 10 day holiday and my data limit is 30. I would be able to use as much of that as I like as long as don’t use more than I would in the UK over a 4 month period?
in regards to data add ons, are they subject to fair usage. E.g. if I got a 10GB add on would I be able to use the full 10GB abroad or would it be capped to fair use.
Hope this makes sense!
