upgrade to 6G but can't connect to Wifi on my Samsung GlaxayA60e
  • 24 August 2023
  • 12 views
switched to new upgrade 6G but now cant get internet connection on my Samsung GalaxyA20e it was working perfectly yesterday so frustrating
Hi @berkovid,
Is it Wi-Fi you are unable to connect to or data via your SIM?
If you are having issues with Wi-Fi it may be worth resetting your network settings.
If it’s the SIM, you can check the coverage checker at the link below:
