How do I use my data in Turkey ..?
Turkey is not an inclusive roaming destination,Â
To use mobile data in Turkey, you need:
- Turn on ROAMING in your iD account (iD app), and on your handset.Â
- Set your iD account bill cap to an amount you’re happy to spend on roaming data use.Â
Should you choose to use roaming mobile data while in Turkey, iD will charge you £1.50 per MB of roaming data used.Â
Why iD
Mobile?
